Can't find my 9401
Hello everybody.
I'm trying to read the frequency of one signal with the module 9401 but I cannot find it in the DAQassistant. I do think I have all the software installed. The cRIO I use is connected to the computer by ethernet. Did I forget installing one driver? Has the ethernet anything to do with it?
I'm lost after following all the guides and help files I found about. Thank you very much in advance.
(2,499 Views)
Accepted by loewesh
Hi Loewesh,
Which version of cRIO are you using? Normally, for cRIO (except the very latest generations), you will not have functionality of DAQAssistant available. cRIO is working with RIO drivers.
Some good starting point is this document: https://learn.ni.com/learn/article/getting-started-with-compactrio-hardware-and-labview
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(2,456 Views)
That was!  Tank you!
(2,438 Views)
