Can't find the file "Agesa Configure Sweep Coupling.VI"
As I attempt to open a recently moved program... I get the following error "Find the VI named Agesa Configure Sweep Coupling.VI".
It seems to give the same message anytime it accesses the agesa directory.  Where can I find this directory, and where should it be located for the program to acess it.
Ed
(2,375 Views)
When you downloaded the driver, you should have placed it in the \instr.ib folder. There are a couple of drivers available for the ESA. If you moved this VI to a new pc, you need to download it again.
(2,371 Views)
