11-22-2007 10:42 AM
11-26-2007 06:14 AM
11-26-2007 08:36 AM
Hello SFK
thanks for your answer. I didn't installed neither the 8.2.0 nor the 8.2.1 RTE, i only installed LV 7.1 and 8.5. That's the reason why there are not more files in the 8.2 folder than the NVIORef.dll (btw.: same with 8.0 RTE!)
I'm using XP SP2 (updated every week)
I installed the default device drivers (including VISA and DAQmx), both 7.1 and 8.5 (incl. 7.1 support, NOT 8.0 or 8.2.x support), and they are all visible in my function palettes. I'm able to communicate with a DAQmx device, but i can't open the testpanels in MAX. So the device drivers seem to work properly.
It seems that the 8.2.1 RTE installation keys were partly written to the registry by 8.5 installation, although the 8.2.1 RTE wasn't installed. From the systems software control panel in the "National Instruments Software" the 8.2.1 RTE was NOT listed. But when i ran the 8.2.1 RTE installer it claimed that the RTE was already installed.
I dared to remove the RTE 8.2.1 installation with the MSIBlast tool. After that i was able to install the 8.2.1 RTE (necause now the registry was clean from that installer).
Now it seems to work. From my opinion there's some kind of version mixing error with the 8.5 installer
