Can't install NI-DAQ 6.6
Hi.
I have bought DAQCard-1200 and I can not install NI-DAQ 6.6 for work with
LabVIEW from CD. I have Win 98 SE.
The first stage of installation passes normally, after that the computer is
restarted and the installation a component for LabVIEW 5.0.1f begins. I do
not see the text in dialogue windows.
Help please.
(2,788 Views)
This is a problem I've had a few times, untill I discovered what it was.
You have to change your Local/Region Settings to America (or US).
Try this and you will notice it will work!
Koen Hoogstoel
National Instruments Belgium
Vadim Gnatkovsky wrote in message
news:3888ebe8@newsgroups.ni.com...
(2,788 Views)
The answer is correct. It does solve the problem. But it is the kind of problem that should not have occurred in the first place, because it is a crude localization error.
(2,788 Views)
