Can't install sound and vibration tookit on 64 bit xp
That's it really. Most programs not designed for use with 64 can still run on it, why won't the toolkit let me install it?
(2,887 Views)
What LabVIEW version did you install before? The Toolkit will install into an existing LabVIEW installation but it can only support 32 Bit LabVIEW.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,867 Views)
I just installed Labview 8.6 and that seemed to work fine. Odd that the program works OK and the toolkit does not.
(2,851 Views)
Thank you for posting to the NI Forums! Our software is currently not officially supported in XP 64-bit. LabVIEW will run in compatibility mode, but it is not officially supported on this OS. The same goes for the toolkit. It may just not install at all on this operating system. Please refer to this knowledgebase for a list of supported operating systems for LabVIEW and the LabVIEW Toolkits.
Margaret Barrett
Digital Multimeters and LCR Meters
(2,832 Views)
