link comment to icons objects
Is it possible to to link comments to objects that it is referring to such as shown in the figure.  This would allow the comment to be moved automatically when i drag the object itself.  I find it cumbersome to have to move the comment and the object separtely when things need to be reorganized.
(2,985 Views)
Accepted by topic author fvnktion
Yup. Right-click on the structure (for-loop, while-loop, whatever) and select Visible Items -> Label. Then enter your text in the label. You can also add a description and tip for it.
(2,980 Views)
simple enough..... thanks!
(2,975 Views)
