Can't open a VI anymore
I have a big problem to open a VI since it makes Labview crash everytime I try to open it...
I send to you the VI:
Thanks for your help.
Message 1 of 13
(4,186 Views)
Hi carolyne,
What version of LabVIEW are you using? I am currently using LabVIEW 7.1 and I am unable to open your file at all.
If you are using LabVIEW 8, perhaps you can resave it so that it is compatible with 7.1 and I will check to see if it crashes as well.
Anthony Wong
University of Toronto
Chemistry Department
Message 2 of 13
(4,173 Views)
I can't open it either... Using LV7.1
Message 3 of 13
(4,174 Views)
Yeah I'm using the 8.0 version.
But I'm not able to save the VI in the 7.1 version because I can't even open it.
What can I do else ?
Message 4 of 13
(4,171 Views)
It opened for me but it is missing a lot of subVIs.  Maybe it is a subVI that is giving you problems.  I resaved it and maybe now you can open it (but it will still be missing the subVIs).
Hope that this helps,
Bob Young
P.S. The second one is saved for previous (7.1).
Message Edited by Bob Y. on 06-27-2006 10:42 AM
Message 5 of 13
(4,165 Views)
Message Edited by JoeLabView on 06-27-2006 11:44 AM
Message 6 of 13
(4,158 Views)
Thank you, I can open it now !!! Smiley Happy
Message 7 of 13
(4,156 Views)
But I have still the same problem than before this last problem, it crashes when I launch it.... Smiley Sad
Message 8 of 13
(4,150 Views)
It may not be your main vi that is crashing labview it may be a subvi that causes the crash. try  opening each of the subvi's to see if they cause LV to crash.
Joe.
"NOTHING IS EVER EASY"
Message 9 of 13
(4,143 Views)
Hi carolyne,
It might be a subVI rather than the main VI that is causing LabVIEW to crash for you.
Edit: It seems Jhoskins thought of the same solution also.
Message Edited by Anthony_Wong on 06-27-2006 10:58 AM
Anthony Wong
Message 10 of 13
(4,142 Views)
