05-02-2006 03:10 AM
05-02-2006 03:51 AM
hi there
i tried to open your vi with LV 7.1 on XPSP2. after selecting the vi from the file dialog LabVIEW shows no reaction at all! then i tried to open an reference to the VI, but "Open VI reference" function returns error code 7 "file not found" (funny...)
i suggest to contact NI, maybe they have more tools.
05-02-2006 04:01 AM
Dear Chrisger,
I have already sent a request to NI.
Thank you for your try, by the way, I'm working with the 8.0 version.
05-02-2006 04:09 AM
ok, but LabVIEW dosn't even reach the point where the version is checked, it shows no reaction at all.
good luck!
05-02-2006 04:56 AM
05-02-2006 02:38 PM - edited 05-02-2006 02:38 PM
Message Edited by Ed Dickens on 05-02-2006 02:39 PM
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.05-02-2006 02:42 PM
7.1 cannot open 8.0 VIs directly. You must first open them in 7.1 and do a "Save As" and select, "Save for Previous Version". It will then save it in a format that 7.1 will be able to open. Of course any 8.0 only features that were used in the VI will not convert back to 7.1 and the VI may be broken and need a little work.
@pincpanter wrote:
Chris,
the same happened to me opening a (supposedly) good 8.0 vi with 7.1. I didn't get any message and of course the vi was not opened.
The vi was intended to give an example of using MathScript nodes.
Paolo
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.05-03-2006 01:54 AM
05-03-2006 02:51 AM
Dear Ed,
I don't know how I did to not save the block diagram, I've already saved a lot of VI and I've never had this problem...
But thank you for you answer.
To insterested persons : Here the answer of my support request :
Hi Caroline,
I tried opening the VI you sent in and it crashes on my computer aswell.
Unfortuneately it seems you VI is corrupted, there is not much you can do
with a corrupted vi other than deleting it and restoring from a backup. The
only thing I would suggest would be to mass compile the VI. To to this open
up LabVIEW goto Tools>>Advanced..>>Mass Compile and select thr directory
which contains your vi. This tool loads up VI's and recompiles them, If it
still crashes then I dont think there is much more we can do.
Regards
Jonathan Bowers
Applications Engineering
05-03-2006 03:21 AM
