05-03-2006 07:46 AM
Not getting the dialog at all is a little strange. My guess would be the VI is damaged. If that's the case, not much you can do except try to find it again.
@pincpanter wrote:
Thanks Ed, I already knew this. But generally we get at least a warning message.
In this particular case, I was almost sure the vi was 8.0, because the author said it contained MathScript nodes (my attempt to open it was a programatically hopeless action, just to be able to say "I tried anyway"), but if we don't know the actual version of a vi we are trying to open and we get nothing, there seem to be two possibility open: wrong version? vi damaged? Boh!? (Boh!? is an Italian way to say "who knows?")
Paolo
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.05-03-2006 08:16 AM
Since you didn't purposly save it without the diagrams, then something must have happened during the regular Save process that damaged the VI. If you don't have recent backup, you're stuck starting over.
@carolyne wrote:
Dear Ed,
I don't know how I did to not save the block diagram, I've already saved a lot of VI and I've never had this problem...
But thank you for you answer.
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.05-03-2006 08:52 AM
