Can't upload LIFA_base
Hi everyone,
I was loading the Arduino firmware onto my Arduino Uno to use LIFA and I have carefully done all the steps still I have got this error while uploading LIFA_BASE file.I have used Arduino 1.06 and VI package manager 2014 version.Is it the reason it can't read the new keywords?
Please tell me what should I change here to make them compatible with eachother or which version should I use?
here is the problem
Never feel ashamed of learning something from others
(4,381 Views)
I am using Arduino 1.0.5 IDE, and it worked for me.
(4,368 Views)
it's still showing the same problem Smiley Sad
(4,340 Views)
I posted a way of uploading the LIFA code to an Arduino Uno, or Mega 2560 without using the IDE.  It just uploads the HEX file directly to the COM port.
https://decibel.ni.com/content/thread/18700
(4,332 Views)
You should also know that lifa has been replaced with LINX - https://decibel.ni.com/content/groups/labview-interface-for-arduino?view=overview#/?tagSet=undefined
Give that a try.
(4,320 Views)
hmm yes.Even I use it .It is way more easir than LIFA for me but using LIFA for a particular reason and this error is confusing.I never faced this problem before in LIFA
(4,304 Views)
You should post to an arduino board about the keyword and what to use instead of Byte.
(4,299 Views)
