Can text be formatted when using 'Append report text.vi'?
The example that ships with LabVIEW 7 'Generate Report from Template (Word).vi' uses 'Append report text' to insert text into a word template via bookmarks.
My question is can this text be formatted in any way (e.g. fontsize, fontcolor, ...)? It seems I can't format the bookmark and I can't format the transmitted text. It always appears in Normal Arial 12pt.
Thanks!
(3,032 Views)
Use the Set Report Font.vi after the New Report.vi. You can set the text color, font, size, etc.
(3,032 Views)
Thank you,
this works well for formatting the whole report. I also found that the Word Format Text.vi placed directly behind the Append Report Text.vi changes the attributes for the previously inserted text at the bookmark.
(3,032 Views)
