Can the FLASH memory in CompactRIO be worn out
As I understand FLASH memory usually has a finite number of erase-write cycles. How many erase-write cycles can the FLASH memory in a CompactRIO have before it is worn out?
I have made a program that stores samples from an analog input unit to the FLASH memory before it is sent to a host computer. I am concerned the memory will be worn out after time.
(2,675 Views)
