hide application in taskbar
Kaixo denei:
I want to launch 20 different applications but i don´t want to see any application in the taskbar. They will be invisible to the user.
Thank you.
Agur.
(4,167 Views)
Set the main window state to hidden.
André (CLA, CLED)
(4,163 Views)
Hi André:
If i put the window hidden i don´t see the front panel, but i can see the application button in task bar and i don´t want to see anything.
Thak you
Eskerrikasko.
(4,130 Views)
Hi Marku,
you want to show a window (front panel) but hide it's entry in the taskbar??? This is clearly not Windows standard! Do you know any other software that behaves like this?
If you want to avoid the windows standard behaviour you should look for this on Microsofts website, maybe they can offer some information on this...
After reading your post again:
Maybe you want to have something like a "service" type of program. Look for this here in the forum - there are many other threads on this, even examples from NI!
Message Edited by GerdW on 11-07-2007 09:17 AM
(4,125 Views)
The service is the way to go.
André (CLA, CLED)
(4,118 Views)
What you want to do is add the line
HideRootWindow=True
to your application's INI file. This will make the second window disappear.
___________________
Try to take over the world!
(4,108 Views)
Thank you for all, ok the way is the service.
Eskerrikasko eta agur.
(4,098 Views)
