control for scaling axes of waveform graph
does anybody know if you can create a control on the front panel for scaling the axes of a waveform graph? I think of a box on the front panel where you check autoscale and if it isn't checked that you then have to enter values for minimum and maximum.
I know that you can change the setting by clicking right mouse at the waveform graph, but I would like to have a control as I don't operate the VI myself.
Thanks.
Steffi
(2,986 Views)
Hi!
   I would have done it setting some property on Graph's property node, but I didn't found the right property for autoscale feature.  To be quick, I made to set Y axis scale style.  I also apologise for naiveness of my example VI, but I spent really few seconds in building it.
   Hope this can lead you to the right way....
   Have a nice day
graziano
(2,983 Views)
Hi Graziano,
thanks a lot for your help. It works for the minimum and maximun, but I also didn't find the autoscale-option at the property node. Maybe you find it another time or someone else knows where it is?
Would be great!
Thanks again,
Steffi
(2,977 Views)
Try the "Scale Fit Property". You should find it in Properties -> Y Scale -> Scale Fit
(2,973 Views)
Yep,  that works!
Thanks a lot!
Steffi
(2,965 Views)
