Can the bounds of a cluster be changed programmatically?
I wish to expand and collapse the bounds of a cluster control using one or two buttons to reveal/hide additional information in the control. Unfortunately, the Bounds property of a cluster control appears to be read only. "Change to Write" on the pop-up menu is grayed and disabled. Is there a way to enable changing of the Bounds property on a cluster and another way to accomplish this?
I don't like the thought of using a sub-panel to achieve something similar.
Thanks in advance for your help.
Larry
(3,502 Views)
I don't think this is possible, but you can show\hide individual controls or have a single control hiding the rest and show\hide it.
___________________
Try to take over the world!
(3,497 Views)
Set the cluster to "size to fit" and make supplemental elements visible/invible when needed. The cluster bounds will adjust to fit the visible elements.
LabVIEW, C'est LabVIEW
(3,487 Views)
Thank you tst and Jean-Pierre for the responses! At first glance I thought the suggestions had some limitations until I realized that "supplemental elements" could include inconspicuous transparent frame decorations. That led to the elegant solution which I demonstrate in the attached vi.
Thank you!
(3,474 Views)
Along the line of JPD's answer, you can set the position of the elements, which will make the cluster larger.
___________________
(3,461 Views)
