Can the true/false position be swapped on a boolean control?
Hello, Is it possible to customize a horizontal boolean control so that it sends TRUE when on the left and FALSE when on the right?
Peg
(2,824 Views)
Never done this...but you can't use a logical not to swap the sides in your code??
Greetings
Christian
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
(2,823 Views)
THis does what u r saying IF my understanding is right!!
Message Edited by muks on 08-13-2008 06:53 AM
(2,815 Views)
You can customize the control and replace the T and F images, but in general it's a bad idea to change things from their default behavior (unless you're planning on playing a prank on someone or that this really makes sense in the system you're doing this in).
___________________
Try to take over the world!
(2,806 Views)
