Can the waveform chart be inicializated?
I am doing a program with Labview and I need to know if is possible to inicializate a Waveform Chart
(2,746 Views)
Hello Carlukos,
What exactly do you mean by initialize a waveform chart ?
To put some data in it at the start of the VI or to erase all the data in it at a certain moment ? I think both are possible... for the second, you can use a property node 😉
Hope this help... let me know if you need further help or example code.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,743 Views)
Yes you can only with charts (not with graphs).
Just create a property node and select hystorical data. In that you can introduce the values (an array) which you can initilize.
Jaime Cabrera
NI Applications Engineering
Jaime Cabrera
NI Applications Engineering Spain
(2,734 Views)
