How do I write to file
I am acquirng a continous 4-20mA using DAQmx read. How can I write the data acquired as excel file, can some explain how to use the write labview measure file function, or is there any better way of writing using some DAQmx write?
My acquisition is from 6 channels, so I would like all 6 readings to be written.
Yemi
(3,221 Views)
if you are acquiring "waveforms" arrays you can use the VI "Write waveforms to file".
Bye
CLD - Labview Certified Developer
(3,202 Views)
Also, to find example code, go to "Help" >> "Find example..." and search for "excel" if you want to write data to Excel document or search for "spreadsheet" if you want to write data to tabulated text documents.
Hope this help
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,199 Views)
