Can these constructs be used in LabVIEW as well?
@RongTime wrote:
I used DBL for the example In testing and actual use, I think there is no problem because I used I32. Thanks for the good point 😄
If you meant "in actual use, I used I32" than I agree there is no problem (in actual use).
Also note that comparing floats for equality is something that is a LabVIEW issue. Every programming language I know off has this problem.
Message 11 of 13
(306 Views)
Also note that comparing floats for equality is NOT JUST something that is a LabVIEW issue. Every programming language I know off has this problem.
I'm missing a NOT there!
But there are arbitrary precision floating point libraries, but they are very domain specific and extremely resource and CPU intensive to use, as they implement a variable length floating point representation. All main stream CPUs nowadays implement the fixed size IEEE-754 format floating point representation and that is also what all modern programming languages I know off use as their native floating point data type.
Rolf Kalbermatter  My Blog
Message 12 of 13
(298 Views)
@RongTime wrote:
Actually, since this is a FOR loop it will stop after 10 iterations, no matter what, and all the blue at the bottom of the loop code is completely redundant. Whatever is wired to N takes precedence.
I agree will all others that your code is highly flawed for what you are trying to do, even if you do I32 for the "points".
Message 13 of 13
(279 Views)
