Can we implement lv random generator in hardware???
Hi ni
I have been use the lv random in my project and now I want to implement my project in hardware
can I implement this  LV random generator in hardware ???
If not then why ?????
Please I need some detail if you can
best regards
m.s
hi ?Q>
Message 1 of 8
(3,423 Views)
Accepted by topic author mangood
The random number function is not available on FPGA. Good random number generation algorithms are complex. I would guess that the LabVIEW function calls one or more functions in the operating system that aren't available on FPGA. Also the random number output is a floating point, which was not supported on FPGA until recently (and I don't know if it's fully supported now, I haven't tried yet).
Message 2 of 8
(3,389 Views)
Yes.  There is a Random number generator for the FPGA.  It is a Galois generator (check out Galois life history for entertainment.  He died way too young and we lost a lot of mathematics!).
Check out the Community page
https://decibel.ni.com/content/docs/DOC-1143
I have used this successfully.
LabVIEW ChampionLabVIEW Channel Wires
Message 3 of 8
(3,385 Views)
thank you kuds for you
but i read this  ."" The algorithm is based on the use of multiple multiplicative congruential generators.""" about this generator
http://digital.ni.com/public.nsf/websearch/9D0878A2A596A3DE86256C29007A6B4A?OpenDocument
what the mean by  "" multiplicative congruential generators!!!!!"""
did any one have a clear information>>>???
hi ?Q>
Message 4 of 8
(3,358 Views)
hi ?Q>
Message 5 of 8
(3,358 Views)
It depends if you really care about the internals of the random number generator.  There is a whole field studying pseudo random number generation.   Note these are not truly random since they are generated by an algorithm.  The algorithm typically used is add the last integer to a large integer and then multiply by another large integer given overflows and dropping the high bits you get a fairly random number.  Chosing the two large integers is a bit tricky to make sure that the numbers won't loop.  You want it to cycle through all 2^N combinations.  There are refinements that involve the last N random numbers instead of just the last.
The Galois generator is a shift and xor operation IIRC and is easier to implement in a FPGA.  If you are really really interested you can read the original articles on the pseudo random number generators since they are documented.
Note that in the FPGA you get a value from 0 to 65535 and not a floating point number from 0 to 1.0.
Message 6 of 8
(3,347 Views)
is you answer is explain to these words """congruential generators!!!!!""
hi ?Q>
Message 7 of 8
(3,339 Views)
Ah, so it is the word "congruential" that is bothering you.  This is because like all pseudo-random-number-generators (PRNG) they have defects.  There are better ones and the low order bits of this one have a serial correlation.  In fact there is some theorem that if you take the random numbers as coordinates in space, the points will lie on a hyperplane of that space.
Look up "conguential multiplicative pseudo-random number generators" and you will find some links on wikipedia and probably wolfram.  This is why they are not good for cryptographic applications.  I believe that Mersenne twisters are the best for statistically good generators.
To get back to the original problem, the Galois PRNG is not cryptographically good since there is a definite pattern in the bits.  Different than multiplicative generators but it is there.  But it is a fine generator for dithering or signal processing.
Message 8 of 8
(3,330 Views)
