Streaming video from network source
Looking to access a third party network resource eventually.  But the other team building that has not completed it yet so I don't know what it will look like.  So in the mean time I was going to try setting up a stream from a LabVIEW web service and accessing it with the HTTP vi's not sure if this is the correct way to do this.  I think I am trying to read the XML stream.  No docs on how to do this.  Was thinking about using .NET to do this but I was hoping for a LV solution.
Anybody have experience streaming data from a web service?
(3,569 Views)
I have found a document to point you in the right direction.
https://decibel.ni.com/content/docs/DOC-9938
Carl W.
Applications Engineering
(3,539 Views)
Thats works well, but what I need is something that can stream from a webservice (not created by LabVIEW).  I was looking at using a LabVIEW webservice to simulate this third party webservice untill I get better information on this.
Createing the webservice that pushes the data out works fine.  But reading that webservice stream is giving me a 404.
I can use the "Get" method seems to work but it takes forever do downlod the data, so its not fast enough for video.
(3,535 Views)
I think what you are trying to do will not be possible in LabVIEW.
Carl W.
(3,522 Views)
