Can we input -.6 mV signal to SCB-68 block? how?
We are using LED and pmt to send the input signal to the SCB-68 connector block. We measured the input with multimeter and it is -.6 mV and I am trying to monitor that with LABVIEW but it is not coming out right....I think I am connecting the input wires to the pins wrong...or there is some other problem...can somebody help me with that...
(2,685 Views)
Yes you can.
THe SCB-68 is used with a variety of devices. The actual concetions depend on what device you are using. The last time I looked, they interface board came with a manual and a sticker that ID'd the connections.
That is as far as I can go with the info you have provided.
Ben
(2,685 Views)
There are two other things to concern about:
Type of measurement: Differential, NRSE, RSE
Voltage range: 0.6 mV are a low voltage so you cannot get good measurements when using a range of +-10 Volt.
As Ben says your manual gives you the answer how to do it.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,685 Views)
