There are two other things to concern about:
Type of measurement: Differential, NRSE, RSE
Voltage range: 0.6 mV are a low voltage so you cannot get good measurements when using a range of +-10 Volt.
As Ben says your manual gives you the answer how to do it.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
