Can we integrate an Aocustic emission sensor with DAQ directly ?
Hi
I am totaly new in this field, i would like to use an acoustic emission sensor to monitor the vibration, but i am not sure if i can connect the sensor directly to the CB-68LP board then to my DAQ.
thanks
Message 1 of 16
(4,490 Views)
It depends on what the output of the sensor is, what type of input it is designed to work with (Hi or Lo Z) what its voltage range is, the frequency of the signal, etc., and which DAQ you have. More information is necessary to allow us to help you determine what might be needed.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 16
(4,485 Views)
Hi thanks alot for the replay and sorry for the delay to respond
the sensor specification can be found here just click on the following link:
The DAQ PCI - 6014
Thanks alot
Message 3 of 16
(4,468 Views)
For me, the link is dead. Can you just tell us the spec instead of linking us to it? Can you also give us the information requested by LV_Pro above? Cheers
Message 4 of 16
(4,462 Views)
Hi all
The Sensor specification are:
Type 8152B1… covers 50 ... 400kHz
Power required  from 5 --- 36 v
Constant Current mA  3 ----- 6
More information in the attached file ( pdf)
This sensor will be mounted on cutting tool holder to monitor the vibration level resulted from the interaction between the wrokpiece and the cutting tool.  from there i want to find out if i can attached directly to the DAQ PCI - 6014 and then the data collected will be stored directly to a local Database (MySQL). so if you have any advice please let me know if i can attache this sensor directly to the DAQ.
Thanks alot all
Message 5 of 16
(4,449 Views)
Hi
Sorry i could not attached the sensor specification file but here is the link it should works:
http://www.kistler.com/mediaaccess/000-204a-03.05.pdf
The one I mean is Type 8152B111
Thabks again
Message 6 of 16
(4,407 Views)
the
Putnam
LabVIEW Champion
Message 7 of 16
(4,443 Views)
the first
Putnam
LabVIEW Champion
Message 8 of 16
(4,443 Views)
the first problem
Putnam
LabVIEW Champion
Message 9 of 16
(4,443 Views)
the first problem I
Putnam
LabVIEW Champion
Message 10 of 16
(4,443 Views)
