Can we integrate an Aocustic emission sensor with DAQ directly ?
the first problem I see
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 11 of 16
(1,326 Views)
the first problem I see is
Putnam
LabVIEW Champion
Message 12 of 16
(1,284 Views)
the first problem I see is the
Putnam
LabVIEW Champion
Message 13 of 16
(1,284 Views)
The first problem I see is with the frequency response of your sensor vs that of your board. The sensor is outputting a signal in the 50KHz - 400 KHz range but the 6014 has a maximum sampling rate of 200 Ks/Sec, which limits you to a range < 100KHz. You would also have to provide some low pass filtering on the output of the sensor(input to the DAQ card) to limit the signal to that range. I think that you could probably hook up the sensor, using the "RMS" output, but you will only be able to look at that limited frequency range to prevent aliasing (google Nyquist frequency). If the 50KHz is sufficient for your needs this may be ok.
P.M.
Putnam
LabVIEW Champion
Message 14 of 16
(1,283 Views)
Smiley Surprised Sorry folks, that was a wierd event. I had typed much of my first line when all of a sudden the editor "blinked" and was blank. I retyped it and sent it only to find that the "blink" had apparently posted the original attempt in the wierd "adding one word" form. I'm really not trying to inflate my message count towards the "enthusiast" categorySmiley Very Happy
P.M.
Putnam
LabVIEW Champion
Message 15 of 16
(1,282 Views)
Thanks all
Message 16 of 16
(1,270 Views)
