Can we use RS422 serial port communication in LabView.???
closing serial port is also done there @Gredw
Message 11 of 48
(4,404 Views)
i installed all the visa drivers perfectly and when i open MAX  it recognise the serail port as COM port , but when it shows the errors please find the following attachments  of images  and suggest me what can i do ??  to solve those errors .
Thank you in advance
Message 12 of 48
(4,414 Views)
1st screenshot: seems, that your VISA resource is occupied by some another process/application. Close all apps, what can use it, and then try again. Also, it's good practice to add to LabVIEW settings, in Options->Environment "Automatically Close VISA Sessions".
2nd screenshot: you didn't select any VISA resource, control VISA Resource Name is empty.
Sincerely,
Message 13 of 48
(4,408 Views)
Hi arun,
just look at the attachment , you may get what is the exact problem i am facing
- You still have NO error handling at all…
- You still use BytesAtPort immediatly after VISAWrite!
- You still use BytesAtPort despite you configured a TermChar!
Last, but not least:
- You don't provide a VISA resource in your VISA resource name control…
When the errors complains about wrong/missing parameters you really should check all parameters/inputs of that function!
Edit:
PLEASE DON'T CREATE DOUBLE THREADS!
Keep discussion in one place! I merged your second thread on the very same topic!
Message 14 of 48
(4,400 Views)
@kosist90  yeah i closed all other applications and i select in environment settings and check mark on automatic visa....
even through it doesnt help us it shows same error , And The same errror occured when we create any VI on serial port
Message 15 of 48
(4,382 Views)
Hi arun,
no need to show the very same image again and again!
Select a VISA resource before you start your VI!
Message 16 of 48
(4,386 Views)
Your VISA Resource Name is still empty.  You have to select which port to use before running your VI.
GCentral
Message 17 of 48
(4,385 Views)
Hi Gredw
I know I am annoying you , But i  am aBeginner ... I get same error even i create any VI on serial port please check the following attachment , i find that example in our forum even i execute that example i get the same problem
can you please edit that VI or suggest me any of your example for communicating over serial port
Thank you
Message 18 of 48
(4,384 Views)
I think i select visa source name ,  check the image .. so can you please how to give visa source name , and what type of name we should give .
Thank you
Message 19 of 48
(4,382 Views)
Accepted by topic author arun2929
Hi arun,
as mentioned several times before:
You need to select that "COM23" resource name in the "VISA resource name" control in the frontpanel of your VI!
I hope I made that clear by now…
Message 20 of 48
(4,374 Views)
