Can you change Endian-ness in LV VISA Serial Communications?
It is basically an array that you index.  See attached.
GCentral
Message 11 of 13
(714 Views)
A lookup table is definetly a possible solution for any kind of swapping/rotation.
I am wondering from your given bytes:
Do they rotate by 1 (01111111 => 11111110 => 11111101 => ...) or
Doe they swap "symmetrically" (0110|1001 => 1001|0110, '|' marks the virtual line of symmetry and is of course not part of the byte)?
As already mentioned, a lookup table will always work, but depending on the situation (like questions above indicate) there might be better performing solutions (at least in regard to exeuction time, maybe even memory consumption).
Norbert
Norbert
Expert: Geometry
Message 12 of 13
(707 Views)
I agree, please show us a few example where there is less symmetry in the bytes.
Message 13 of 13
(695 Views)
