Can you change tabs on a tab control by using boolean buttons?
Need to change tabs by pressing a button instead of using the actual tabs.
Message 1 of 9
(4,848 Views)
Absolutely. First create a local variable for your tab control. Then poll your boolean to tell when its value has changed. Finally write a value to the tab's local variable to change its tab page programmatically.
Message Edited by Jarrod S. on 02-07-2007 05:46 PM
Jarrod S.
Message 2 of 9
(4,843 Views)
Yes, but how would you do it, let say if you had 20 booleans through out the front panel and you needed them to jump to other tabs?
Message 3 of 9
(4,834 Views)
Sounds like a case for an event structure that acts on a value change for each boolean button. Inside each event case, wire a value to a property node for the tab control
Message 4 of 9
(4,825 Views)
Message 5 of 9
(4,823 Views)
All right, I got that far! Can not come up with a way to give a value to the boolean pushbutton to change events?
Message 6 of 9
(4,818 Views)
You don't even need the property nodes.
Message 7 of 9
(4,818 Views)
Well done unclebump, this is just what I was looking for!  Thanks
Message 8 of 9
(4,816 Views)
I'm not sure I follow what you mean. If you are writing to property nodes for the boolean button, you need to use the Value(Signaling) item.
Message 9 of 9
(4,815 Views)
