Mouse Move Event Outside vi
Hello Everyone,
                I need to detect the mouse move event outside a vi. Whenever I move mouse on any part of the screen, I should detect it in a vi that may even run minimised. Please give your suggestions.
Vasanth.
Ya Ya
Message 1 of 15
(5,844 Views)
Hi, Ya Ya,
You can use Acquire Input Data.vi like shown on the screenshot below:
VI also in attachment (LV 8.2)
best regards,
Andrey.
Message 2 of 15
(5,836 Views)
        Thank you Mr.Andrey. I need to know whether the mouse have moved or not. How can I know that? Is there any event available for that?
Vasanth.
Ya Ya
Message 3 of 15
(5,832 Views)
I'm not sure that you will be able to get mouse event within VI without polling.
Theoretically you must create Hook-DLL, which will collect mouse activities and then will set occurence in LabVIEW. Relative complicated...
But if you need event, then you can fire event programmatically as shown on the screenshot below:
best regards,
Andrey.
Message 4 of 15
(5,825 Views)
Andrey,
            That is great! This is what I exactly wanted to do. Thanks for your help.
Vasanth.
Ya Ya
Message 5 of 15
(5,822 Views)
Andrey,
           Is there a way I can capture this event in the OS level? i.e, directly registering the OS level event onto LabVIEW user event?
Vasanth.
Ya Ya
Message 6 of 15
(5,798 Views)
Yes You can,
you should find the .net event for the mouse movement and create a callback VI which will react on the .net event
Ton
My LabVIEW Ideas
Message 7 of 15
(5,787 Views)
Ton,
Good idea, but I'm not sure that its can be done only with .net, because the .net Framework provides no built-in facilities to handle hooks.
But if you will found the .net event, please post example. Its a very interesting for me too. Thanks!
Andrey.
Message 8 of 15
(5,774 Views)
Check this site in the NI website that instructs how to handle the windows messages in LabVIEW
Ya Ya
Message 9 of 15
(5,743 Views)
Though this helps only for handling the mouse messages over the specified VI.
Vasanth.
Ya Ya
Message 10 of 15
(5,742 Views)
