Can you give me some suggestions for encryption decryption
ok i've written my own encryption decryption techniqu can you suggest me some better methods
Message 1 of 8
(4,815 Views)
Can you convert it to 2011.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 8
(4,794 Views)
What do you mean by better? ... More secure? Faster? Reliable? Practicality? Feasibility?
Have you published this wok in a journal or conference proceeding?
This paper is a few years old, but you could start here: http://ieeexplore.ieee.org/xpl/articleDetails.jsp?tp=&arnumber=1598556&queryText%3DA+Performance+Com...
Message 3 of 8
(4,766 Views)
How about this?
I made it to work for text files, but it will work for binary files too with very little modifications.
Basic encryption is simple XOR a data stream and a repeating key, decrypt by XOR the encrypted data with the same key.
The longer the key the more secure the encryption.
=== Engineer Ambiguously ===
Message 4 of 8
(4,737 Views)
Not to publish ... this is very simple ... i just want to know should i improve this or scrap this
Message 5 of 8
(4,715 Views)
You should not store the encryption key inside the encrypted file.
This makes your encryption weak in general.
You seem to have "security through obscurity" in your enc/dec algorithm.
Message 6 of 8
(4,698 Views)
You haven't replied but I guess I haven't answered your question either...
Sure it works but from a LV programming standpoint it is very redundant and Rube Goldberg like.
IMHO you should scrap what you have or at least clean it up.
I am a long ways from being a LV expert but there are the things that pop right out at me when I see your code.
You use identical code in three places, make it a sub-vi.
Why start with a constant of -1 and increment it once inside your for-loop? This value will always be 0.
Don't use array size to set the number of iterations of your for-loop then use the iteration counter to index an array inside the loop, use auto indexing.
Your block diagram is sloppy and hard to follow.
Message 7 of 8
(4,651 Views)
The topic of this thread has been revisited And other alternatives posted.
Message 8 of 8
(4,408 Views)
