Can you help me with an electrical diagram?
Here you have a Block Diagram and Front Panel images of the VI, you can build it in LabVIEW 6.
I hope this help you, if not, let me know
Message 11 of 30
(1,322 Views)
It appears then that you have a homework assignment. Given that you will need to tell us what you've done, and what specific help or guidance you need. We will not do your homework for you.
As for the VI that was posted, don't bother with that - it's just a Boolean switch connected to an LED with a pretty picture on the front panel. I doubt very much it's what you need.
Message 12 of 30
(1,322 Views)
Thank you for the Block Diagram and Front Panel, i think this is what i needed. I will try to do it, but there is one more thing to it...i must put a condition that if the current is to big, then the lightbulb will burn. Can you help me with that also?
Message 13 of 30
(1,309 Views)
Why don't you try something? Like looking in the Comparison palette.
ajimenez: Please try to not provide the full answer. After all, you won't get the points for providing the answer to the homework assignment.
Message 14 of 30
(1,303 Views)
Yes, it is a homework assignament. I have to do an electrical diagram in Labview, as i written above, where i have a battery, a switch and an lightbulb. When the switch is on, the lightbulb must turn on, but if the battery power is to big for the lightbulb, then it will burn it. This homework is not at the LabView class, it is at class called Electrical Measurements. This is extra for a higher grade. So i entered cause i know i find here people who know LabView. If you can help me this is perfect.
Message 15 of 30
(1,300 Views)
I think I understand the problem now. The battery is a control, and the switch is a Boolean control. Then the "battery" is in a certain range, and the switch is on a indicator will light up. As a first Labview assignment I think it make sense. But I will leave the rest up to the OP.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 16 of 30
(1,284 Views)
Ok, i have the battery connected to the switch, if the switch is off, then it won't happen anything so the problem is over, but i have the case when the switch is on then i must compare the value of the battery to a constant, if the value is smaller then the bulb will light, if not, it will burn. This is the problem, if i write it in code is simple, but it is hard to me in labview, that is all...that is why i asked your help. 10x
Message 17 of 30
(1,278 Views)
Ok, i think i`m on a good run. So, i made two controls - the battery and the switch. The battery i connected to an "In range and coerce" (if the value of the battery is between min and max then is good). The both controls go into an boolean "and" and this is connected to the light bulb. There are no errors but it isn`t working. Where am i wrong. I putted a photo also.
Message 18 of 30
(1,257 Views)
Hello....pls...help!!!!
Message 19 of 30
(1,246 Views)
Don't understand your problem. If 'On/Off Switch' is true and 'Batter' is greater/equal to 'Min' AND less than 'Max', 'Light Bulb' is true.
Why are you using the In Range function when you originally stated you only needed a less than comparison?
Message Edited by Dennis Knutson on 01-09-2010 10:42 AM
Message 20 of 30
(1,241 Views)
