Can you help me with an electrical diagram?
Yes, that was my logic too and there are no errors, but when i run it the 'in range and coerce' blinks and nothing happens. What should i do?
Message 21 of 30
(1,374 Views)
Sounds like you set a breakpoint. Clear it (right click - Breadkpoint>Clear Breakpoint)
Message 22 of 30
(1,369 Views)
Nope, there is no breakpoint. I did a test, i changed the "and" with an "or" and it works only when the switch is on....it doesn`t work in the case when the battery is between min and max. And the problem with the blinking it was because i pressed PAUSE. Any other suggestions?
Message 23 of 30
(1,364 Views)
I did it instead of the "min-max" just a "bigger" cause i just wanted the value to be less then a max. Thank you for the help.
Message 24 of 30
(1,357 Views)
Changing to a an OR is not at all correct.
Post the VI because when I reproduce your code, I have no problem at all. If using LabVIEW 2009, please save it as 8.6 before posting. Before doing that, clean up your wires and verify the Min control is actuall connected to  lower limit input of the In Range function. Can't tell from your image because you got wires on top of other wires (bad idea).
Message 25 of 30
(1,356 Views)
Ok, i changed it and it is saved in 6.1 (this version i`m running). I`m waiting an answer cause it would be better to be with a min and max then an bigger.
Message 26 of 30
(1,347 Views)
Do you really think that 0 is a Max value and that 6 is a minimum value?
Message 27 of 30
(1,341 Views)
hahahah stupid me ... i thought it was the other way around. Thank you. 🙂
Message 28 of 30
(1,337 Views)
another question -- how do i change the range for a numerical control (for example instead of 0 to 10 i want it to be from 0 to 120)
Thank you
Message 29 of 30
(1,324 Views)
You can set the control properties>range from the front panel by right-clicking in the control.  in 6.1 you can even force the vi to suspend if the value is out of range.
I never understood why this great debugging tool was taken away and i kinda miss it. (and hated having to reconfigure everything when I uprgaded)
Message 30 of 30
(1,318 Views)
