06-12-2009 05:19 AM
I have Labview version 8.2.1 installed. Is there a way for me to open a VI built in version 8.6?
Thanks for answering,
Benjamin
Solved! Go to Solution.
06-12-2009 06:18 AM
Hi Benjamin,
Thanks for the post and I hope your well today.
There is not away to open new VIs in older versions of LabVIEW. If you attach the LV8.6 code, I can open it in LabVIEW 8.6 and save it to LabVIEW 8.2 (save to Previous version).
Hope this helps,
06-12-2009 07:01 AM
In Labview 8.6 it is possible to save for previous version down to 8.0, as mentioned by Hillman. So if you know the person behind the VIs you may ask him/her to use the save for previous version option. If you do not know the source post your VIs in a new thread and ask for some conversion to Labview 8.2 help.
