 Alain_S
			Alain_S
			08-13-2009 07:41 AM
Coq Rouge wrote:
ssteel wrote:yes, but the code doesnt work, it doesnt just strip the backslash but the whole date??
My favourite hyperactive question mark is back in business
Indeed the previous post of ssteel is more than incomprehensible
08-13-2009 07:42 AM
 Mathan
			Mathan
			08-13-2009 07:46 AM
ssteel wrote:
how come file path out isnt connected to anything?
Its not at all needed.... But if you want just connect it after the build array and see what happens.....
Mathan
 parthabe
			parthabe
			08-13-2009 07:49 AM
You mean, out of the Write to Spreadsheet String.vi?
Like Cou Rouge already told you, "The path going out is only a copy."
If you want you can use it by passing it to another function that can accept it as input or just display it in an indicator.
08-13-2009 07:50 AM
 parthabe
			parthabe
			08-13-2009 07:53 AM
Mathan wrote:But if you want just connect it after the build array and see what happens....
Hi Mathan,
I think you meant the Build Path function.
 Mathan
			Mathan
			08-13-2009 08:32 AM
Ya partha....  thanks........
 thanks........
