Cannot Compile Control & Simulation loop
Hi I try to compile a simulation, and the problem is a feedback loop
that is not accepted.
I want to write a program that strips the signal of its DC-component, and controls the amplitude of the remaining AC-signal
through a feedbackloop. The PI-regulator controls the gain of an amplifier.
(3,146 Views)
Accepted by topic author laskar01
Hello laskar01,
Instead of the feedback node, use Memory VI.That should solve your issue.
Andy Chang
(3,140 Views)
