Open ended Fuzzy Membership
How do I go about making a Membership function that would be like sloped from a <= b and 1 for x> b?
(3,548 Views)
Accepted by topic author punkmonkey
You can use the trapezoid membership function with the limits as limits as [a, b, above +range,  above +range].  This is equivalent to x been aways 1 until yoiu reach the limit.
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,524 Views)
Yep, that's what I did. I put in something remarkably high and it worked. It would be nice to be able to put in infinity if possible. I'm trying to generalize the contoller as much as possible.
(3,517 Views)
