Cannot Display Varient Data
I am trying to display data that is being received from an inertial sensor via activex. It seems that I can read the sensor properly but cannot display the varient data that is being stored. I tried just an indicator to view the data however I get the message: Value->Array(Non-Displayable). If I use a Varient to Data block and put an array as the data type the program will crash. Any suggestions?
Message 1 of 12
(5,306 Views)
Hi kyle123,
are you sure you get your data as an array? To see your data you can use first a variant indicator.
Mike
Message 2 of 12
(5,305 Views)
I'm pretty new to labview, how would i go about doing that?
Message 3 of 12
(5,301 Views)
Hi kyle123,
right click on your variant output and select create -> indicator. Do you have a description for the activex function you use? Why do you think you get an array of data?
Mike
Message 4 of 12
(5,288 Views)
OK so i put the indicator in and the data box in the front panel displayed: VALUE->ARRAY(Non-Displayable)
I also tried to put the Varient to Flattened String function in and it displayed: OLE Varient
Message 5 of 12
(5,284 Views)
Hi kyle123,
please give some more information about your activex function!
Mike
Message 6 of 12
(5,282 Views)
Hi kyle123,
                  Can you post your code that you have tried so far?
Message 7 of 12
(5,279 Views)
haha, sorry. here's what i've got so far
Message 8 of 12
(5,276 Views)
Can you post your vi for lv 8.0? or a screen shot of your block diagram?
Message 9 of 12
(5,271 Views)
I think this will work, otherwise, here are the jpeg's
Message 10 of 12
(5,252 Views)
