recursive classes in LabView
I have an urgent question.
Is it possible to use recursive classes in LabView?
That means creating a class, that references an array of objects of the same class in the private data-cluster.
Otherwise, does anybody know a workaround?
Greetings,
Lorand
(3,373 Views)
Hi Lorand,
I believe this KB will be of some assistance to you. It give some instructions about how to create recursive VI's in Labview.
Message Edited by mickeyw on 08-07-2008 09:20 AM
Mike W
National Instruments UK&Ireland
(3,371 Views)
Hi mickeyw,
thanks for your reply.
But your answer doesn't match my question. I'm talking about recursive CLASSES (object oriented programming).
Lorand
(3,364 Views)
I believe you can't have a class in itself, but you should be able to have it in one of its children. This and this might help.
___________________
Try to take over the world!
(3,340 Views)
