Cannot Get MAX Working Right
I am running Windows 7.  I work in a mechanical engineering lab and we have a Labview program that uses Labview 2011, so I'm forced to use the 2011 version. We have a small program that reads thermocouples through an NI DAQMX.
I am having the hardest time getting this thing working correctly though. After I install the software suite and drivers and start up NI MAX I get this error:
The exception occurred in the NIMax process in the function CmxExecutionThreadPool::DoWorkNonUI.
See these files for details:
C:\ProgramData\National Instruments\MAX\Logs\20160720_091809-NIMax-0000018C.log
C:\ProgramData\National Instruments\MAX\Logs\20160720_091809-NIMax-0000018C.dmp
After which, MAX is unresponsive and I have to close it.
I have tried to do a complete uninstall and reinstall at least 5 times now and everytime I get this error. I'm installing from the cd's.
It's becoming increasingly frustrating. We have another computer in our lab that is identical in every way to mine and installed Labview on it and it all worked perfectly, but for some reason on my computer I run into an error every time.
Someone please help me.
(3,740 Views)
(3,726 Views)
You could perhaps install the latest version of NI-MAX? It will work with older versions of LabVIEW and DAQmx.
Also, have you tried resetting the NI-MAX database? http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9
(blog)
(3,734 Views)
I tried that as well, I updated to the newest version of MAX and updated the NIDAQMX drivers to the most recent drivers that would work with Labview 2011.
(3,732 Views)
