Cannot build exe
I am trying to make an exe and get this message"The following files have links to help files that are invalid. Open the files and fix the help links."
Does anyone know a procedure to fix this problem?
Brian
(5,014 Views)
Can you provide an image of the error message so that we can see which files might be at issue?
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(4,984 Views)
Here is the error message.
C:\Program Files\National Instruments\LabVIEW 8.0\menus\Universal Library\Das16.llb\DCFGPORT.VI
C:\Program Files\National Instruments\LabVIEW 8.0\menus\Universal Library\Das16.llb\ERRMSG.VI
C:\Program Files\National Instruments\LabVIEW 8.0\menus\Universal Library\Das16.llb\DOut.VI
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 7 occurred at ABAPI Check Help FIles.vi -> ABAPI Dist Cmp Settings to Disk Hier.vi -> ABAPI Get Settings From File.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Rule_Editor.vi -> EBUIP_Item_OnDoProperties.vi -> EBUIP_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux.
NI-488:  Non-existent board.
Brian
(4,979 Views)
I have the same problem with SVT VIs. I asked for support 4 weeks ago, but did not get any reply.. Here's my log:
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Check for Waveform Parameter Continuity (no state).vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Get SV Channel Info.vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Set dB ref if Pascal.vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Extract Unit Label (channel info).vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Unit Label Manipulation.vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Unit Label Lexical Class.vi
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\NISVL\_NISVL.llb\svl_Caller VI Returned in Error Source.vi
(4,907 Views)
I fixed the VIs in question now by going into the individual libraries and then going to properties->documentation and deleting the path to the help file. But in my opinion this is an annoying bug that should be fixed.
(4,904 Views)
Thanks Timo.   I will try your suggestion.
Brian
Brian
(4,883 Views)
Hi, Please check out this link. it is likely solve your problem.
http://digital.ni.com/public.nsf/websearch/1F25EBE7E7A07E91862571110080EA0E?OpenDocument
Message Edited by houhit on 10-09-2006 08:56 AM
(4,655 Views)
