datatype mismatch
Over the last two years, I have been working on a utility to enter test data from a hand written test report into Access 2000 using Labview 6.1 with the Database Toolkit.  Now I have been asked to add an edit feature to the utility.  The idea is to display the data after a search by serial number and modify a couple of fields and then update the database table.
Several of the entries have infinity recorded in numeric fields.  This was not a problem when I used the parameterized insert into query (DB Tools Insert Data.vi).  I can add and read the Inf values.  The database tables show 1.#Inf.
However, when I try to use a SQL command including a where statement, I get a data type mismatch error.
I would like any suggestions for modifying the update either in the formatting of the SQL statement or using a parameterized query.
Sandra Wells
(2,953 Views)
I found a work around.  I set the Infinity values to 1.79769313486231E+308.
Thanks for looking at this.
Sandra Wells
(2,931 Views)
