Cannot build project-need to select startup VI
How do I select a VI to be startup VI when building labview project?
(4,784 Views)
Hello hershey1
Your question is bit confusing!
Do you want a VI which runs as a startup VI during development? OR
Do you want a VI which runs as a startup after creating EXE?
(4,782 Views)
I cannot create an exe from a labview project becauase I do not how to select a VI in my project as startup VI
(4,778 Views)
Select the vi at left and press the right arrow
(4,775 Views)
1. Populate all your Vi's in the project.
2. Right click on build specifications
3. Select new EXE.
4. Go in source files.
5. Select your VI which has to added as a startup VI
6. Click on the arrow as shown in the image.
(4,765 Views)
The posters above are correct.  If you run into any more questions about Application Builder, check out this link:  NI Developer Zone Tutorial:  Distributing Applications with the LabVIEW Application Builder
(4,726 Views)
