how to specify channel here
hi
i need to specify channel here in this picture, i am aquiring two signals from NI-USB 6212 on ai0 and ai1, and using labview 8.6.
any idea how could i put correct channel on this conversion node
thanks
(2,580 Views)
You don't have to sepcify anything since the Split Signal function is giving you the second signal. If you wired the Convert From Dynamic Data directly to the output of the DAQ Assistant, then you could specify a channel.
(2,560 Views)
i did the same but i am getting some problem it is not actually splitting the channel, i have two separate waveform graphs, when i change amplitude or frequency of any one of  the signal it effects the others out put i dont know why i have connected both of my signals on channel ai0 and ai1, can u plz have a look on my VI here
http://forums.ni.com/ni/board/message?board.id=170&message.id=387122&jump=true#M387122
and suggest me what i gonna do now.
thanks
(2,545 Views)
