Cannot connect to remote Mitsubishi OPC server using datasocket
I can read OPC items locally using datasocket, however if the client is in another PC I get error 1184 when I try to connect to an item. The datasocket Select URL does work, though.
Both computers are Windows 7 machines in the same workgroup sharing the same user/password.
I'm able to read items through the DSC OPC client (but I don't want to use DSC). This seems to indicate that security DCOM settings are good.
I know that there is plenty of documentation about remote OPC access and DCOM and I read most of the docs, by NI and other sources, to no avail; none of the docs are mentioning this specific error code. Any suggestions?
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,101 Views)
Accepted by topic author pincpanter
Well, it's typical... After two days of efforts, just 40 minutes after posting my question I got the solution in another thread of this forum.
The Remote Registry service must be running on the server machine.
Now I only need to carefully rewind some of the many settings I did, to find the minimum working condition.
Paolo
(3,091 Views)
