Cannot delete file from lvlib
I am not able to delete a missing file from lvlib. Can anyone help with this?
Saranya
Message 1 of 11
(6,110 Views)
Why did you want to delete this? What you really want to achieve? Post bit more details.
Mathan
Message 2 of 11
(6,106 Views)
I am trying to create a zip file from my project and seems like it wouldn't create it until I sort out all the missing VIs in the project (Everytime I click Preview in the Zip File properties page, it points to a VI that does not exist and says File not found). I was able to remove some of them. But could not delete the file shown in the picture.
Saranya
Message 3 of 11
(6,099 Views)
Can you please tell what is the full warning message in the picture you attached.
Message 4 of 11
(6,093 Views)
Here it is!
 -Saranya
Message 5 of 11
(6,090 Views)
Can you drag it from the lvlib to the project?
Try to use the 'Resolve conflicts' function in the toolbar  of the project (the triangle warning sign)
Ton
My LabVIEW Ideas
Message 6 of 11
(6,082 Views)
Ton,
I am not able to drag it out of the lvlib. Also Resolve Conflicts is disabled.
-Saranya
Message 7 of 11
(6,071 Views)
Is the LVLIB locked (I don't see a key)
Ton
My LabVIEW Ideas
Message 8 of 11
(6,052 Views)
Ton,
The lvlib is not locked.
-Saranya
Message 9 of 11
(6,035 Views)
Accepted by Saranbalu
Ok, the hard way, open the lvlib witha text editor (notepad) and delete the element that contains the missing VI.
Do this on a copy to make sure the lvlib stays intact.
Ton
My LabVIEW Ideas
Message 10 of 11
(6,020 Views)
