Cannot find "Use Transparent Name Labels" for Front Panel in Tools - Options - Front Panel - LabVIEW 2010
I've been studying a style guide which suggests turning on "Use Transparent Name Labels" from the Front Panel Options.  I cannot find this setting in Tools - Options - Front Panel.  Did this parameter setting go away or was it moved somewhere else in LabVIEW 2010?
(2,896 Views)
Yes, that was removed in 2009. You can set it back by following the instructions mentioned in the following KB article:
Changes with the Options Dialog Box in LabVIEW 2009
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,888 Views)
Thanks for responding.  I am using LabView 2010 and find no token named "noBoxAroundName", as described in the reference article, in the LabVIEW.ini file.
(2,879 Views)
Accepted by wildcatherder
You have to add it.
noBoxAroundName=True
(2,876 Views)
Fair enough. Thank you.
(2,873 Views)
