11-29-2021 06:37 PM
Hello
I'm trying to install a new software into my cRIO 9076, although i'm getting the following error:
Something is strange because i have the cRIO connected with RJ45 cruzed patchcord to my PC, MAX can detect that, they are in the same subnet mask, but i can't install nothing.
Someone have a tip?
Thanks.
11-29-2021 09:20 PM
Your crio is having link local ip address. even though your crio and system is in the same subnet, is your system ip address is also on the same range???
11-30-2021 01:50 AM
Hello Kartiknattar
yes, they are in the same range. Although i cant change anything in cRio and i no wonder why...
11-30-2021 04:10 AM
Reset the crio and try again.
11-30-2021 04:18 AM
I have already done that and nothing change. Even the ip is the same.
11-30-2021 04:33 AM
Is your system ip address static or dynamic?
Make sure it is static
11-30-2021 05:02 AM
What is the IP address of the network adapter in your computer that you connected to the cRIO?
11-30-2021 08:49 AM
I have static IP address.
Ethernet adapter Ethernet:
Autoconfiguration IPv4 address: 169.254.114.xxx
Subnet mask: 255.255.0.0
cRIO:
IP: 169.254.73.125
same subnet mask
Maybe i have to change 73 for 114?
11-30-2021 08:58 AM
Nop, it can't work.
03-26-2022 09:34 PM
Hi!
did you solve the problem.
I got same with SBRIO 9626.
Can you share the solution?
