Cannot install software on cRIO 9076
Hello
I'm trying to install a new software into my cRIO 9076, although i'm getting the following error:
 Something is strange because i have the cRIO connected with RJ45 cruzed patchcord to my PC, MAX can detect that, they are in the same subnet mask, but i can't install nothing.
Someone have a tip?
Thanks.
André Simões
Work with LV2019 and cRIO since 2021
Message 1 of 11
(4,500 Views)
Your crio is having link local ip address. even though your crio and system is in the same subnet, is your system ip address is also on the same range???
CLD Using LabVIEW since 2013
Message 2 of 11
(4,474 Views)
Hello Kartiknattar
yes, they are in the same range. Although i cant change anything in cRio and i no wonder why...
André Simões
Message 3 of 11
(4,458 Views)
Reset the crio and try again.
Message 4 of 11
(4,447 Views)
I have already done that and nothing change. Even the ip is the same.
André Simões
Message 5 of 11
(4,444 Views)
Is your system ip address static or dynamic?
Make sure it is static
Message 6 of 11
(4,441 Views)
What is the IP address of the network adapter in your computer that you connected to the cRIO?
Rolf Kalbermatter  My Blog
Message 7 of 11
(4,437 Views)
I have static IP address.
Ethernet adapter Ethernet:
Autoconfiguration IPv4 address: 169.254.114.xxx
Subnet mask: 255.255.0.0
cRIO:
IP: 169.254.73.125
same subnet mask
Maybe i have to change 73 for 114?
André Simões
Message 8 of 11
(4,424 Views)
Nop, it can't work.
André Simões
Message 9 of 11
(4,419 Views)
Hi!
did you solve the problem.
I got same with SBRIO 9626.
Can you share the solution?
Message 10 of 11
(4,150 Views)
