Cannot locate CVT library?
Hello everybody.
First of all, I have to tell you that I am using Labview 2014, and I need to use the CVT reference library for a project.
All is well and nice, except for the fact that I have installed it using vipm and I can't locate it.
part of the code is inherited and I have no choice but to solve the issue with the dependencies.,..
Could you please help me with some suggestions?
Thank you.
(3,766 Views)
I have LabVIEW 2013. The CVT library is located in the 'Addons' functional palette. On the disk you can find the VIs at C:\Program Files (x86)\National Instruments\LabVIEW 2013\vi.lib\NI\Current Value Table\ (In your case 'LabVIEW 2014' instead of 'LabVIEW 2013')
(3,752 Views)
Hi chembo,
Thank you so much for your help. I have one more question...where do I find the CVT Get Label VIs? Have they been removed or do i need to download them separately?
(3,736 Views)
