Cannot open connection in a peer-to-peer netword
Thanks very much. Appreciate the help along the way.
Message 11 of 13
(679 Views)
Scott,
     This post is two months ago, don't know if you still remember.
     I set up the PDA ip to be 192.168.1.X, it works for TCP/IP functions; but now when I tried UDP functions, it does not connect again. Here is the link to another post. Can you help find the problem?
 http://forums.ni.com/t5/LabVIEW/PDA-only-receives-UDP-data-when-connected-to-PC-fails-wirelessly/m-p...
Message 12 of 13
(626 Views)
It looks like Verne is taking care of this issue and will help you answer these questions.
Message 13 of 13
(615 Views)
